Honda CR-V & Element 2WD & 4WD Element & CR-V
Radiator Problem
Old Jun 13, 2013 | 10:10 AM
Ali Raza's Avatar
Icon2 Radiator Problem
Dear ,,,
Yesterday i was driving my CRV 2008 model,, suddenly i feel that AC is not cooling, i tried two or three times switch on & Off the AC but it didnt work,,, than i look at the temperature bar it was rising, i got surprised i switched off the AC and tried to stop,,, as i was on the main road it was rush hour,, after a while i managed to stop and check the radiator,,,,, it was empty and the attached bottle was also empty. i got shocked ,,, i started the vehicle and put water in the radiator,, after waiting for some time ,,, i move my car and reached the destination,,,, on second day i again check the radiator ,,, but water was full,,,,
can u suggest what should i do,,,,,,one thing more should i use coolant or distilled water for the radiator now.
Thanx & Regards,,
Ali
Last edited by Ali Raza; Jun 13, 2013 at 10:13 AM. Reason: want to add some more text
Old Jun 13, 2013 | 10:42 AM
kiseliok's Avatar
Default Re: Radiator Problem
What kind of climate do you drive in?
If your car ever sees temperatures below freezing, you'll need coolant for sure.
Old Jun 13, 2013 | 06:12 PM
Sticker Bomb's Avatar
Take it to a shop to get checked out. You have a leak somewhere.
You don't want to run water at all if it gets cold where you are, because it will freeze, and it will crack the engine block.
maddmike24
Jul 31, 2011 08:17 PM
seahorse12
Honda Civic (2001 - 2005)
Jun 12, 2011 09:11 AM
OverkillSD
18
Jul 23, 2009 01:46 PM
WillEat4F00d
Aug 19, 2007 03:20 AM
Mr_Q
Jun 25, 2005 01:20 PM
