r12 to r134a retrofit fittings hit the hood
Old Jun 12, 2013 | 08:45 AM
DelCarajo's Avatar
Default r12 to r134a retrofit fittings hit the hood
I'm trying to retrofit my 1993 Del Sol Si and the damn fittings I bought stick up too high and hit the hood. They were the ones you can buy at autozone. Anyone have experience with a set that works? Do I need a 90 degree bend?
Old Jun 12, 2013 | 08:50 AM
sleepyaccord96's Avatar
Default Re: r12 to r134a retrofit fittings hit the hood
yes a 90 degree bend style would be better...
that or just simply give your a/c line a little push downwards... these lines get moved and a little bent sometimes when doing an engine replacement. So with you doing a small push downward to bent it justtt a little itty bit wouldn't hurt anything
Old Jun 12, 2013 | 07:42 PM
DelCarajo's Avatar
Have people actually used these 90 degree fittings or are there people that find straight ones that fit? Anyone want to chime in with what fittings you used and where you got them from?
Old Jun 13, 2013 | 12:26 AM
fragmare's Avatar
Maybe try adjusting your hood stoppers up a tiny bit? I have a 93 DX and the tall conversion fittings work ok.
belairbrian
Jan 29, 2015 04:10 PM
fireant
Jan 14, 2009 04:20 PM
trevorjohn88ef
Paint and Body
Dec 1, 2007 10:27 AM
SlamminS85
Mar 31, 2006 02:58 PM
FrOsTwHiTeDC4
Feb 6, 2006 05:09 AM
