PARTING OUT : SUPERCHARGED EK HATCH: JRSC, Si , Hasport , B18c1 , Koyo ]]]]]]]]]]]]]]
I will update this thread as the summer goes on with whatever small items I have that are nice enough to take the time to post up. Prices are my bottom dollar to avoid useless haggling.
Text for pics: 616-TWO-83-TWO-098
$240
HASPORT EK D/B Mounts, 3 piece. In Excellent condition, only have approx. 7k miles. No torn or ripped bushings, come with ALL hardware needed!
$250
Stainless steel DC B Series header, comes with "test pipe" and o2 sensor.
$60
GS-R AEM Short Ram Intake. In good shape and filter is like new.
$375
Skunk2 PRO-S Coilovers. These also have just under 7k miles about, never driven in winter. They rode awesome at the height I had them.
$160
KOYORAD Aluminum 1/2 Sized Radiator. Works great and in good shape.
$300
MINTY Rear disk swap, good calipers, pads, rotors, etc. INSTALL AND GO. Comes with absolutely everything needed! No searching for parts or anything of that sort.
$10
PWJDM radiator stay in red.
$70
RARE 02-04 RSX A-Spec OEM rear lip. Has a 3" crack on the BOTTOM area that is not visible on the car, could be easily zip tie frankenstined or plastic welded.
$180 + Stock dohc vtec (in return, this is a trade only)
MINTY woodgrain "burlwood" valve cover. The clearcoat wasnt done professionally so it's about an 8/10.
$30
Difficult to find minty OEM B16/Gsr spark plug cover.
$40
Rear T Bracket for B series into Ek swap. From a 99 Si.
$240
$250
$60
$375
$160
$300
$10
$70
$30
$40
Bump for true statements.
This would be perfect for someone considering the JRSC so they can see how everything is hooked up.
Want the hood and possibly the radiator, are you willing to drive the 30 minutes to Gingerman this weekend? Hood is a definite, radiator is a possibility if you're down for swapping it out at the track. Let me know!
Jake
Jake
