Transmission & Drivetrain Gearboxes, Differentials, Clutches
03 rsx 2nd and 4th gear problem
Old Jun 10, 2013 | 08:10 PM
kazaa187's Avatar
Default 03 rsx 2nd and 4th gear problem
I just changed tranny with supposally good tranny it wont go into 2nd gear and grinds 4th could i have screwed something up on install
Old Jun 10, 2013 | 11:47 PM
Runnerdown's Avatar
Default Re: 03 rsx 2nd and 4th gear problem
Unless the clutch is not releasing fully, but this should cause an issue for every gear change. I'm betting you got a junk tranny, it happens all the time. People sell **** and then when it doesnt work right they just say it was fine when they had it.
Old Jun 11, 2013 | 03:12 AM
Emerica459's Avatar
Did you change your cable routing at all? Make sure the cables are connected properly and aren't binding somewhere. Only reason I say this may be the case is you are pulling the shifter back for both of those shifts and that activates the same cable. But the other response may be right though, used parts is always a cluster ****.
Old Jun 11, 2013 | 12:49 PM
kazaa187's Avatar
I didnt route the cables different but today i was messing with it and i pulled the cable off and shifted it manually an it goes in and stays in 2nd fine
Old Jun 13, 2013 | 06:37 AM
Gearspeed-Performance's Avatar
Sounds like a possible selector set issue. Let me know if you need anything, we have sleeve sets available
phantomgreyhatch09
K Series
Jul 29, 2010 12:55 PM
clekers
Aug 30, 2009 10:59 PM
ED8REX
Mar 9, 2006 09:22 AM
blueintegra90
Feb 11, 2004 01:12 PM
blueintegra90
Feb 10, 2004 06:37 PM
