96 civic dx b16a2 ecu
Old Jun 10, 2013 | 03:20 PM
gitarman2's Avatar
Default 96 civic dx b16a2 ecu
I have a B16A2 swap from a 99 civic si in my 96 DX hatch. The ecu I am running is a p2p. Ive been told from countless people that I should run something else so I caved and got a p28 with an obd2>obd1 harness that is chipped and tuned for my car. It runs terrible on the p28. Does anyone know what basemap I should be using? Also is there a better option than p28?
Old Jun 10, 2013 | 03:22 PM
B_Swapped93's Avatar
Default Re: 96 civic dx b16a2 ecu
Once chipped it doesn't matter p28 p72 p73 and so on. Did this p28 come with the correct base map ?. you can change the chip out vs getting a new ECU
Old Jun 10, 2013 | 03:54 PM
gitarman2's Avatar
Well the seller said it was but what is the correct basemap?
Old Jun 10, 2013 | 04:09 PM
carlos8's Avatar
for basemap leave the p2p, Just get the p28 tuned.
Old Jun 10, 2013 | 04:12 PM
gitarman2's Avatar
So I can't just replace the chip? I have to get the p28 tuned?
Old Jun 10, 2013 | 04:13 PM
NO you CAN replace the chip with a correct base map for a b16 burned on it. getting it tuned is for when you're done your build a base map just helps it till you have the money for a tune.
Old Jun 10, 2013 | 04:24 PM
gitarman2's Avatar
Oh ok good. What is the correct basemap?
Old Jun 10, 2013 | 04:29 PM
the one for your engine and what's done to it.
Old Jun 10, 2013 | 05:21 PM
gitarman2's Avatar
Just headers and exhaust. Someone else told me I needed a p30 basemap?
Old Jun 10, 2013 | 05:38 PM
again once chipped it doesn't matter. get a basemap for a b16.
Old Jun 14, 2013 | 05:13 PM
gitarman2's Avatar
Just received my obd1 eprom chip from Phearable.net and it still isnt running right. I notice a loss of power in low RPMs and the exhaust pops quite a bit when I let off the gas. Could it be the actual ECU is damaged and not the chip?
Old Jun 14, 2013 | 05:19 PM
any codes ? check the TPS for any dead spots poping when you take your foot of ? you mean backfire that may indicate running rich. check your plugs.
Old Jun 14, 2013 | 05:47 PM
gitarman2's Avatar
No codes no dead spots and I just replaced the plugs. Ill check them tomorrow though
Old Jun 14, 2013 | 07:07 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
this thread makes me want to die. you can tune a obd1 ecu for the correct stuff or can run an obd2 p30. That is all
PS or you can add the evap system and run a 99-00 SI ecu I think a P2T with a jumper
bOOsT-FeIn
May 1, 2011 08:35 PM
VTIargentina
Apr 25, 2010 10:13 AM
DraginTeg93
Mar 17, 2007 04:16 PM
SL_RICK83
Mar 5, 2006 07:46 PM
mjrage
Jul 3, 2004 04:02 PM
