b20vtec running low and idling rough when warm
Old Jun 9, 2013 | 08:23 PM
joiv21's Avatar
Default b20vtec running low and idling rough when warm
Its really only rough once it starts warming up then it gets bad but when its cold it idles at about 1k - 1800 rpms like when i first start it up it seems alright.
Also if i give it any throttle itll die unless you rev it hard and build the rpms up but when you build the rpms up when you let off the throttle it just dies like strait stalls.
Itll die even if you drove it and push the clutch in to engage or disengage when the rpms fall. I have a little blow by but thats because my rings arent seated yet still got less than 50 miles on it. hopefully they seat good.
But if i have a milled b16 head 5 thousandth over would i need to advance or retard my cams? If so how much.
I am running on a basemap of a b20vtec with stock internals which is what i have.
Old Jun 9, 2013 | 08:24 PM
joiv21's Avatar
Default Re: b20vtec running low and idling rough when warm
idling low and running rough i mean. lol. backwards as fuh.
Old Jun 9, 2013 | 11:20 PM
joiv21's Avatar
come on now
Old Jun 9, 2013 | 11:31 PM
jbpnoman's Avatar
Your timing is off, fix it.
Your idle isn't set correctly, fix it.
Get the FSM for the 96-00 Civic. It includes directions for the SI for both procedures. That's the section you need.
ShopTech
Honda Civic (2001 - 2005)
Feb 5, 2016 08:40 AM
Shikaido2004
Jun 10, 2008 05:01 PM
Dwalker
Dec 24, 2007 08:23 AM
Teaser
Sep 19, 2007 02:17 PM
PM-Performance
Mar 6, 2004 06:53 AM
