90 accord misfiring
Old Jun 9, 2013 | 12:34 PM
bad71chevy's Avatar
Default 90 accord misfiring
My friend has a 90 accord that is misfiring on the #2 cylinder. You can unhook the plug wire and nothing changes in the running of the car. Also if you stick the end of that plug wire to metal it sparks. I have changed the injectors around and nothing different. Im leaning toward the ecu but not sure. Any ideas??
Old Jun 9, 2013 | 09:25 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 90 accord misfiring
Have you done a compression test on that cylinder?
Checked the spark plug wire for damage/resistance? Installed it may be grounding out before it reaches the plug, check the distributor cap/rotor for excessive wear/corrosion as well.
Old Jun 9, 2013 | 10:59 PM
holmesnmanny's Avatar
like mike said do a compression test and if it's bad do a leakdown test to see where the issue is
could be intake valve, exhaust valve, blown cylinder
madc321
Sep 12, 2012 04:50 PM
freezerman
Sep 25, 2010 02:47 AM
B18CivicHatch
Aug 24, 2007 12:13 AM
themex77
Feb 17, 2007 02:29 PM
J WALES
Jan 13, 2006 10:18 PM
