2000 honda accord code p0705
Old Jun 9, 2013 | 12:20 PM
chriscar00's Avatar
Default 2000 honda accord code p0705
code p0705 came up and i tested all the solenoids and they checked out ok. When the car goes to shift the rpms jump up aprx 300-400 rpm. just seeing if anyone had any ideas thanks
Old Jun 9, 2013 | 12:25 PM
MidasGuy's Avatar
Default Re: 2000 honda accord code p0705
P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
Old Aug 24, 2013 | 07:55 PM
dlangford's Avatar
I have a similar problem with a 99 accord automatic. The check engine light came on as well as the maintenance required light. Several error codes (P0705, P0706, P0420 & P0430). I've seen P0420 before, replaced oxygen sensor at exhaust manifold and it went away. I'm new to the forum and can't seem to find anything about the short in transmission range switch circuit error code. any help would be appreciated.
Old Aug 25, 2013 | 05:46 AM
Lost Again's Avatar
Recheck the codes? I see a P1706 and P1706 for the trans range switch
Ali Hussain Ali
Apr 8, 2014 07:48 PM
psphilip
Sep 9, 2013 04:43 AM
joshua89
Jul 30, 2011 01:36 PM
jwc104
Nov 17, 2009 07:44 PM
