Help! - D16Y8 starting issue
Hi guys,
First post as I've only recently got a 96' Del-Sol - UK Spec.
Car was fine the first few days, then died when I tried to start it...it'll only crank but not fire the engine.
So far I've made sure:
-engine is getting a good spark
-battery is fully charged
-fuel pump is running and getting power
-injectors are getting power but don't seem to be pushing any fuel into the engine.
It will fire briefly with ignition fluid added to the air-intake so the engine seems fine, which makes me believe it's either the ECU or wiring...
Can anyone tell me how to check the ECU wiring etc? or something I may have missed?
Has got check engine light on...although I dont have a reader to diagnose it at the moment. And I live on steep hill, if I push it out and it wont start I have no way of towing it back to my driveway...
http://www.instantservicemanuals.com...1998-download/
There is a buyable pdf download of the service manual it will have the schematic in it and look for the pcm on it and fuse box and find the pin # on the pcm back probe with volt meter on that pin KOEO(Key On Engine Off) you should have battery (12.5-12.6V) or a 5v refrence depending what other modules are "talking" to the pcm
And just because the fuel pump is getting powere doeset mean that it has enough pressure to operate the FPR (fuel pressure regulator) or to spray out of the injector and there could be corosion on the powere wire to the fuel pump so is the fuel pump getting 12v or 3.5v honestly you seriously need to invest in a volt meter i reccomend the fluke 87 true rms multi-meter they run about 400 USD$ 308 euro but trust me that is the best and cheapest multi-meter to get.
Jdm95 - thanks for the input, I have a voltage tester - although not a 400$ one it reads well. Already pulled the PCM out, so if anyone has any advice on what pins to check I'd be grateful!
Just checked the cel - only one code a code 41 - O2 sensor heater? But that shouldn't stop the engine firing should it?
Key has to be on engine of becaue as soon as the key is on everything starts to comunicate with the pcm and i forgot to pull the schmatic today at work i was really busy sorry but i will look up the pin #s tomorrow forsure and will tell you which ones to "probe" te hehehe lol
javifunksEK
11
Mar 11, 2010 04:06 PM
dc2teg2006
Aug 25, 2008 08:20 AM
