low compression cylinder 3
Old Jun 8, 2013 | 05:14 PM
blue_dlb's Avatar
Default low compression cylinder 3
i just bought a used jdm motor n cylinder 3 has 150 dry cold test. the others have a little over 200 dry cold test. wet cold test on cylinder 3 show about 210. so im assuming the rings on 3 is bad. also i see a puddle of oil inside intake mani. do u think i can daily drive with bad ring in cylinder 3 for a year? motor is not in car yet.
Old Jun 8, 2013 | 05:19 PM
grumblemarc's Avatar
The Grumpiest
Default Re: low compression cylinder 3
Lemme get my crystal ball...
Old Jun 8, 2013 | 05:21 PM
blue_dlb's Avatar
Shut up grumpy
Old Jun 8, 2013 | 08:11 PM
Runnerdown's Avatar
Wipe the oil out and run it for a few days. then repeat the comp test.
Old Jun 8, 2013 | 11:47 PM
holmesnmanny's Avatar
Do a leakdown test to confirm results and diagnosis of bad rings.
Old Jun 9, 2013 | 05:06 AM
The Grumpiest
Waiting for someone to answer this question.
Seriously? If it is jacked up either fix it or drive it until it goes. Those are your only two real options. This "what if" stuff doesn't get you anywhere.
Old Jun 9, 2013 | 08:40 AM
froggy0231's Avatar
if it was me id take the head off ,drop the sump off and fit new rings with big end bearings as if you carry on driving it you will damage the cat if 1 is fitted but obviously check the bores before spending out
02BladeRider
Jul 7, 2017 05:49 AM
uberEFtuner
Apr 11, 2014 06:11 PM
StockDC2
Sep 4, 2007 05:58 PM
trecool44
Jun 19, 2007 06:52 AM
Takumi Fujiwara
May 2, 2006 06:34 AM
