Bushing replacement id? help?
Old Jun 6, 2013 | 10:36 PM
Wilka's Avatar
Default Bushing replacement id? help?
I think it's called the compliance bushing or "strut rod bushing" It's on the front lower control arm and mounts to the frame, on the arm that holds the sway bar bushing.
I found an OEM part number, trying to see if there is an energy direct replacement or a direct bolt in fix, I see where it looks like it has a bracket that encases it? Was wondering if all you do is unbolt it and the bushing falls out and place new one in and bolt down or what the story is, was wanting some feedback.
Part # : 51395-SR3-N02
I notice my ball joint creeks and I'm just going to change that bushing while I'm down there and then order the Hardrace front lcas with the other two bushings pre-pressed in the next two weeks.
Old Jun 9, 2013 | 06:32 PM
Wilka's Avatar
Default Re: Bushing replacement id? help?
bump
Old Jun 9, 2013 | 06:36 PM
TypeRfit's Avatar
RESIDENT
If you are going to buy HardRace lca's, you might as well scratch that and just buy the HardRace master bushing kit. More bang for your buck. The master bushing kit also includes the Compliance Bushing.
Old Jun 9, 2013 | 08:33 PM
98civdx's Avatar
Master Detailer
ES does offer a replacement. However you can only get it in the Control kit, IIRC.. It's also smaller than the OEM part. Not sure what it affects, but just something I noticed.
As far as removal/install. the is a nut on top of a washer. Remove that nut and washer and you can slip the bushing off and replace it.
Old Jun 10, 2013 | 05:24 AM
sleepyaccord96's Avatar
thumbs down for ES... I bought their master bushing kit and 2 years later they are falling apart,
I am going for the hardrace LCA bushing to get me by for now and then i will buy the complete kit.
i do not recommend Energy Suspension brand...their shifter bushings are ok but suspension stuff kinda sucks.
Old Jun 10, 2013 | 05:27 AM
grumblemarc's Avatar
The Grumpiest
Took JHP 4 weeks to get the Hardrace stuff back in stock when I ordered RTA bushings.
Old Jun 11, 2013 | 08:28 AM
Wilka's Avatar
I just don't wanna deal with the hassle of pressing in or burning out the old bushings.. time that my car is down does come into play considering I daily it and live in an apartment, it's not so much what I do but just how long the car is in the air. I just don't trust myself to do it in a day or two of fiddling around.
Old Jun 11, 2013 | 09:56 PM
98civdx's Avatar
Master Detailer
There is no burning or pressing with these specific bushings.
Prudz_lude
Sep 22, 2011 11:42 AM
dfJDM
12
Jan 8, 2011 09:18 PM
moco_machine
10
Aug 19, 2008 09:36 AM
95dc2
16
May 13, 2005 06:15 AM
