Help vitara build d16z6 rod bearing clearances????
Old Jun 6, 2013 | 09:05 PM
EG-SIXV-TEC's Avatar
Post Help vitara build d16z6 rod bearing clearances????
help need some help due to the clearances i have with my d16z6 vitara build. this setup will be for turbo after break in.
okay i am using eagle h beam rods and vitara pistons in my setup for boost.
i have already plastigauged my bearings ACL STD bearings on my mains and my rods.
on my Mains i had .0015 straight across the bearings.
and on my Eagle rods i have .001 straight across.
i assume my mains is a go leave it as is.
but how about my eagle rods, w/STD bearings i got .001 across torqued it to spec like 43 ft lbs. according to the eagle.
can i use .001 on my rods? what would be bad to go that tight.
or should i go at least .0015 clearance. how would i achieve that ???
need some major help...
i need this thing running my motor in my car needs replacement asap...
Old Jun 7, 2013 | 03:17 AM
blackeg's Avatar
Default Re: Help vitara build d16z6 rod bearing clearances????
Do not go with .001 on the rods. Between. 0015 and. 002 is ideal. Since they seem even across all 4 rods look into the acl bearings with hx in the code they provide more clearence. If not then maybe oem red or pink will get u up a bit
Old Jun 7, 2013 | 10:06 AM
KevinEF7's Avatar
I do believe .001" is to tight
ACL race bearings will give you a .0015-.002" clearance
Old Jun 7, 2013 | 10:07 AM
grumblemarc's Avatar
The Grumpiest
How many threads do you need asking about clearances? I count at least half a dozen.
EG-SIXV-TEC
Jun 21, 2013 07:37 PM
EG-SIXV-TEC
May 31, 2013 08:35 AM
iownahatchback
Jan 31, 2010 05:54 PM
altoid
May 18, 2003 07:17 PM
