Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission swap
Old Jun 6, 2013 | 02:46 PM
sledheadkevin's Avatar
Default Transmission swap
OK all I have a 1999 civic dx that the trans is going out on, I also have a 1997 civic ex that everything is falling apart except for the motor and trans. what I am wondering is will the 97 trans fit right in my 99?
Old Jun 6, 2013 | 04:48 PM
94EG8's Avatar
Seagull Management
Default Re: Transmission swap
If it's a 5 speed, yes. It's geared better for accelation too. If it's an automatic it'll bolt up and work, but it will shift a little weird and it will throw a CEL (P0715)
Old Jun 10, 2013 | 07:45 AM
Ok so they are both automatic, how bad will the shifting be and what is a CEL (P0715)?
Old Jun 10, 2013 | 01:00 PM
94EG8's Avatar
Seagull Management
Originally Posted by sledheadkevin
Ok so they are both automatic, how bad will the shifting be?
Ehhh, it's different. It will start out almost normal, and it wont throw a CEL right away, but it will just shift progressively worse the more you drive it.
Check Engine Light. If you have any state emissions testing it wont pass with this transmission, it throws a code for a mainshaft sensor IIRC due to having a different 3rd gear ratio. The PCM thinks the trans is slipping.
Old Jun 17, 2013 | 06:06 AM
Thanks for the info, I guess I'll try to figure something else out.
JTom79
May 4, 2014 04:13 PM
civic08
May 27, 2011 01:35 PM
Sfehr
May 12, 2011 03:55 PM
rugimpy
Jul 25, 2010 08:03 PM
slonga
Feb 7, 2009 02:26 PM
