mini-me question, did a search and couldnt find answer
OK i did a bunch of searches, read a lot of topics, here is my confusion.
d16a6 block
d16y8 head
Using a chipped d16a6 ecu, with high fuel maps and rev limit.
NOW.
1. I use the d16a6 distrib. Y or N?
2. If I am using the D16y8 intake manifold, do I have to do any re-wiring to make it fit with the current obd0 wiring.
OR
Is it better to just say screw it and keep the d16a6 manifold?
OR
Is it better to use the D16y8 manifold and use the d16a6 TB
Really not sure, but I want to know this before I get into all of the work.
d16a6 block
d16y8 head
NOW.
OR
OR
1- use ur A6 distribuitor... it will bolt in to the Y8
2-well i am not sure., but i know u can even use a Z6 manifold on stock harness. ( i do) just use the MAP on the TB and not the firewall
3-dont change TB if u using the Y8.. the Y8 its bigger....
2. yep
3. yep
does anyone know if the y8 intake manifold would be a hassle to use?
MrRabbit87
Oct 3, 2008 08:33 PM
honda616
11
May 20, 2007 01:51 PM
1.8Tities
79
Nov 20, 2002 06:40 PM
CRXSleeper
Sep 18, 2002 05:19 PM
