a/c clutch not engaging!!
Old Jun 6, 2013 | 12:01 PM
jdmeg6fan's Avatar
Default a/c clutch not engaging!!
I have a 94 civic that I recently put stock motor back in. a/c worked fabulous before I pulled it out. well I went to a shop to have my a/c recharged thinking it was gonna blow cold. the clutch didn't engage. when I start it up after its been sitting for awhile it'll engage for about 5mins but barely blow cold.. I'm completely lost on what to do tried searching and searching .can't seem to get it...plus it's nearly in the 100° I need ac plz help
Old Jun 6, 2013 | 04:21 PM
jdmeg6fan's Avatar
Default Re: a/c clutch not engaging!!
any body?
Old Jun 6, 2013 | 06:33 PM
Former User's Avatar
Does the condenser fan run when the compressor clutch does engage?
Old Jun 7, 2013 | 11:46 AM
jdmeg6fan's Avatar
yes the fan turns on and the idle changes. I also jumped the pressure switch an still didn't kick on.
Old Jun 10, 2013 | 08:30 AM
Psychoteen101's Avatar
under charged or over charged system possibly. Make sure the shop put the correct amount of freon in there
Old Jun 10, 2013 | 11:29 AM
jdmeg6fan's Avatar
yes it was interchanged but not it doesn't get cold. clutch stays on longer but doesn't get cold like it should. possibly the expansion valve?
Old Jun 10, 2013 | 01:42 PM
slowcivic2k's Avatar
Check the compressor clutch connector for 12V when the A/C Switch is pressed. If 12V is present check the compressor ground wire, and if intact, replace the clutch. If voltage is not present you will need to diagnose the relay that controls power to the compressor to start.
CrossCountry
19
Jul 7, 2016 06:03 AM
BSDMotorSports
Jul 28, 2013 04:12 PM
gnarlycs
34
Jun 20, 2012 08:00 AM
Mackln308
Jul 30, 2010 11:34 AM
all-mtr-teg
Mar 1, 2008 11:32 PM
