Skunk2 intake fuel rail studs stripped?
Old Jun 6, 2013 | 09:46 AM
dedmanchan's Avatar
Default Skunk2 intake fuel rail studs stripped?
I replaced the fuel rail on my XSi head recently in order to relocate the FPR to the end so I could put the IAT sensor canon plug back in. After doing that I got a leaking #1 injector. I pulled the fuel rail to check the o-rings and when I tried to reinstall the studs that hold the fuel rail down stripped. The center stud is fine but the outside two are basically done.
What can I do here? The center one actually loosened up and came out but I can't break the other ones free, I'm assuming they can be replaced right?
Old Jun 6, 2013 | 09:49 AM
B_Swapped93's Avatar
Default Re: Skunk2 intake fuel rail studs stripped?
yes get some vise grips and have at it. easier with the ITM off. XSi what's that ???
Old Jun 8, 2013 | 02:15 PM
Potenza's Avatar
Can you clean up the threads with a die?
Old Jun 8, 2013 | 02:18 PM
grumblemarc's Avatar
The Grumpiest
Originally Posted by B_Swapped93
XSi what's that ???
Maybe he meant SI head?
Old Jun 10, 2013 | 08:00 AM
dedmanchan's Avatar
Man, sorry to leave this hanging out there. I didn't get notification of replies til this morning.
I've tried the vise grips and can't get them to budge. I ordered a stud extractor tool through Oreilly but it hasn't come in yet. I've had luck with the tool before on different applications so hopefully it will work on this too. I think the threads are so far gone it wouldn't be worth trying to repair them at this point. Where might I go about getting new ones? Would I have to have them custom made?
From what I was told from the person I bought the car from, the XSi is one of the variants of the first integras with vtec. They were apparently referred to as RSi and XSi depending on the trim level. It's basically just a B16 DOHC Vtec head.
Old Jun 10, 2013 | 09:55 AM
You're right there, mind you that "xsi/rsi" are chassis codes for the eraly integra. the engine is a JDM B16A first/2nd gen I pb blasted the **** out of them heated them then proceeded with vise grips. gl
Old Jun 11, 2013 | 11:47 AM
dedmanchan's Avatar
Yeah, I got the driver side stud out yesterday with this method. Still working on the pass. side. I have no idea how the hell these studs got so screwed up. Definitely going to need two new ones. The center one is still good, though. Very odd. Also , the outside two have a different length on the shaft. So much so that I'm going to need a spacer of some sort to tighten the rail down fully if I find identical replacements. Any idea what's up with that?
Old Jun 11, 2013 | 01:02 PM
believe it or not my middle one was fine also . not sure why they made them different lengths you can use the factor spacers to have the rail sit flush.
Old Jun 14, 2013 | 10:52 AM
dedmanchan's Avatar
I used two M6 x 1.00 x 25mm bolts for the ends and some washers as spacers since I had no factory spacers. It actually looks pretty clean and works well. As long as I stay free of fuel leaks I'll be happy with it.
Thanks for the info guys.
InTheZoneAC
Apr 9, 2013 05:04 PM
HondaCivic2006
Honda Civic (2006 - 2015)
Aug 15, 2009 02:13 AM
4gencivicef9
24
May 31, 2009 07:59 AM
n2oisfun
Mar 1, 2005 07:10 AM
