Honda CR-V & Element 2WD & 4WD Element & CR-V
1st gen CRV oil pan question
Old Jun 6, 2013 | 08:34 AM
sa90eg's Avatar
Default 1st gen CRV oil pan question
quick question:
(rt4wd) 1st gen crv,
will a b16 ,L/s or gsr oil pan fit?
also would the morosso oil pan fit on my rt4wd crv
Old Jun 6, 2013 | 09:24 AM
LDForget's Avatar
Default Re: 1st gen CRV oil pan question
Originally Posted by sa90eg
quick question:
I've got a built GSR with a moroso pan on my crv with the awd tranny. So yes, it will all fit.
Old Jun 6, 2013 | 09:46 AM
dogbiscuit's Avatar
I think he means will it fit on a B20 block, right?
Old Jun 6, 2013 | 09:54 AM
sa90eg's Avatar
yes sir
Old Jun 6, 2013 | 09:57 AM
dogbiscuit's Avatar
I found this, looks like it's not compatible with the B20
https://honda-tech.com/forums/forced-induction-16/anyone-w-b20-using-moroso-oil-pan-383016/
Do you want a OEM one from a 1998 B20? I still have my old one. it's covered in sludge and will need some cleaning i was going to take it to the recycling center tonight, tired of a huge box of old blown up engine out in my garage.
I can get you some pics tonight if interested?
Is the pan on the B16/18 not as tall? I bet if you picked up one of those and the strainer it would work. The b20 strainer might be taller which makes the moreso pan not work. I'm guessing on all of this....
Old Jun 6, 2013 | 10:33 AM
sa90eg's Avatar
https://honda-tech.com/forums/showthread.php?t=383016
goodlookin out bro, the reason im asking this question is because im planning on installin a greedy turbo kitt on my V
i wanted to tap my oil line befor the install or jst get a MOROSSo pan
Old Jun 6, 2013 | 10:45 AM
LDForget's Avatar
b20 and b18 share the same block...itll fit.
Old Jun 6, 2013 | 11:11 AM
sa90eg's Avatar
TY
Old Jun 6, 2013 | 12:50 PM
LDForget's Avatar
you'll need a GSR pickup though if youre using a gsr pan.
Darknessezz
Oct 6, 2007 06:08 PM
Gamefreak0109
Jun 30, 2007 11:40 AM
Tuan
May 14, 2002 05:07 AM
