thought i ran out of gas? prelude 96 si
Old Jun 5, 2013 | 05:44 PM
LudeAct's Avatar
Default thought i ran out of gas? prelude 96 si
just purchased a 96 prelude si a week ago. excellent running car with 222k mi. however, a bit of a guzzler. i had 3-4 bars left on the way to work today and 3 bars when I arrived to work. the gas light was on and off so I assumed it was still okay. but after a few blocks my car wanted to shut down. i tapped the gas pedal harder and can feel the car lose power. finally it shut down and when i looked at the meter again there were no bars left. i turned off the car and back on, it fired up effortlessly. the gas meter showed 2 bars. i was able to drive it to a gas station to fill up, but it took only 12 gallons. what can be the problem? I know the fuel capacity is 14.9 gallons so what happened to the other 3?
Old Jun 5, 2013 | 08:24 PM
thirsk66's Avatar
Default Re: thought i ran out of gas? prelude 96 si
Other three gallons? Your Prelude Si should have a fuel tank capacity of 15.9 gallons. Sounds like a bad fuel gauge in your cluster or possibly a faulty fuel level sender/sensor.
Old Jun 6, 2013 | 06:39 AM
LudeAct's Avatar
Faulty fuel level sender/sensor, interesting. Is this part of the fuel pump?
Old Jun 6, 2013 | 11:21 AM
thirsk66's Avatar
its near the fuel pump as far as I know. Try replacing it if you have the time to do so.
Old Jun 6, 2013 | 11:23 AM
stravi757's Avatar
sounds like more than just your gas gauge is faulty if your car is dying. you could start with checking clogged fuel filter.
Old Jun 7, 2013 | 07:57 AM
LudeAct's Avatar
Will do, hopefully the part's not too expensive. I will definitely look into it. Thanks man.
Old Jun 7, 2013 | 07:59 AM
LudeAct's Avatar
Post Re: thought i ran out of gas? prelude 96 si
I ordered tune-up parts already which includes a fuel filter which everything should arrive today. Hope I can get it all done this weekend. Thanks for the advice.
furious94ls
Mar 11, 2014 07:28 AM
SoFresh1189
Jul 6, 2011 09:56 AM
ever'sneighborhood
Classic Hondas
Jun 19, 2009 05:58 PM
PIBBSTER
Oct 9, 2005 08:27 PM
-slow ej-
Mar 21, 2005 11:51 PM
