Do I need an ECT sensor?
Old Jun 5, 2013 | 05:38 PM
jemo1's Avatar
Default Do I need an ECT sensor?
I'm working on a D15b in a Mini Cooper. I sent my original harness to a guy and he added the relays and took out what I don't need. The harness tha came back has the water sensor plug that plugs on the thermostat housing but there is no plug for the ECT sensor. Do I not need this now? What does it do differently from the water sensor plug/sensor?
Old Jun 5, 2013 | 05:46 PM
SiWannabe's Avatar
Default Re: Do I need an ECT sensor?
The sensor on the thermostat housing is a fan switch. Correct me if I'm wrong someone, but I think the Coolant Temp Sensor is on the distributor side of the head, near the block and is one wire. If you care to have a temp sensor in the dash, I'm pretty sure that's the way to go about it although I have NO clue on the cooper part. Also, I'm not entirely sure how vital it may or may not be to have that information sent to the ECU.
Hopefully I'm not lying to you, but I DO know that the one on the thermo housing IS the fan switch.
Old Jun 5, 2013 | 05:50 PM
jemo1's Avatar
Ok ok well there is another plug I do have that is for the temp gauge so I think I have that covered. Maybe the ECT is for the ECU input? It's on the other side of the distributor kinda where the transaxle bolts on
Old Jun 5, 2013 | 05:55 PM
SiWannabe's Avatar
If it weren't dark, I'd post a pic but yes, I believe we are speaking of the same little guy with 1 round pin sticking out.
WhiteTrashedDA9
Mar 20, 2013 07:08 AM
jtrig
May 31, 2011 06:25 PM
kramer06
Jan 24, 2008 05:41 PM
Simmerman
12
Sep 18, 2007 07:05 PM
acy76
Apr 12, 2004 09:50 PM
