Transmission & Drivetrain Gearboxes, Differentials, Clutches
integra making horrible whining noise , when clutch is releasing!!!
Old Jun 5, 2013 | 05:23 PM
bbrian's Avatar
Default integra making horrible whining noise , when clutch is releasing!!!
so i did a pull the other day everything was fine i come to a light and i press the clutch in , shift into first , release the clutch and it just make a whining noise , sounds terrible , but if cars in neutral doesnt make any sound at all if clutch is engaged or disengaged , doesnt make any whining sounds when im driivng just releasing the clutch into gear , clutch is a exedy twin disc !!!
Old Jun 6, 2013 | 06:42 PM
Runnerdown's Avatar
Default Re: integra making horrible whining noise , when clutch is releasing!!!
The twin discs are noisy clutchs by nature. It is possible that something on one of the discs is damaged. Without really knowing, you may want to drop the tranny and inspect it.
Old Jun 11, 2013 | 05:06 PM
bbrian's Avatar
bump
Old Jun 14, 2013 | 10:09 AM
doTERRA's Avatar
I had a very similar problem with my car, I adjusted the clutch pedal, where it attaches to the clutch master cylinder. Now is it gone. Jeez was that noise horrible. Apparently it was putting a lot of stress on the clutch throw-out bearing.
Check to make sure your clutch master and slave cylinders aren't leaking, if they are, replace them.
siboii08
Honda Civic (2006 - 2015)
Mar 27, 2008 08:35 AM
jbsmith
Aug 29, 2005 12:21 AM
E Swift
Dec 1, 2004 02:57 PM
jdmcivicferio
Jul 9, 2004 02:15 PM
killerslp
Jan 25, 2004 05:35 PM
