Compression test results??????
Old Jun 5, 2013 | 06:07 AM
djsimm89's Avatar
Default Compression test results??????
Ok i have a h2b car and i just put it all back together and it didn't want to run right had new dizzy intake manifold new sensors ext. Was driving the car and it was overheating my cel came on for ect (coolant temp) got the car off the highway and it died and wouldn't start back up. Towed it to my house and did a compression test readings were 140 145 150 140 now in cyl 3 i poured a cap full of oil in the cylinder and ran the test again and the compression went up to 180. I think the car has a bad head gasket but someone told me when you put oil in the cylinders and the compression goes up that means the rings are bad. If its just a head gasket ill just slap another one on but how can i tell if the rings are bad without removing the pistons and rods?
Old Jun 5, 2013 | 12:23 PM
djsimm89's Avatar
Default Re: Compression test results??????
Bump
Old Jun 5, 2013 | 05:11 PM
djsimm89's Avatar
UPDATE!!!!!!!!!!!!!! took the head off and the headgasket looks fine there is some light scarring in the cyl walls but nothing that dosent look normal so im lost any other way to see if the rings are shot
Old Jun 6, 2013 | 04:13 AM
djsimm89's Avatar
Bump
Old Jun 6, 2013 | 05:39 AM
Pippen_001's Avatar
Those compression test numbers are very low!!
How did you test this? Did you let the motor warm up & opened the throttle body when cranking the motor?
A stock motor (with stock cams) should be around 200 psi. Depending on which compression of course.
Old Jun 6, 2013 | 08:46 AM
djsimm89's Avatar
motor was running for a while then cooled down for about an hour or so did not open throttle body and its a bone stock motor so if the compression should be 200 its no where near that. the head gasket is pine but i cant tell if the piston rings are good or not i did drop oil in the cyl when i tested it and it raised up to 180 if that means anything regarding the rings
Old Jun 6, 2013 | 12:32 PM
h24 eg's Avatar
perhaps stuck to the piston rings, but if the engine is overheated piston-cylinder gap increases dramatically
Old Jun 6, 2013 | 04:42 PM
djsimm89's Avatar
what do you mean by perhaps stuck to the piston rings
Old Jun 6, 2013 | 06:47 PM
h24 eg's Avatar
try to pour the liquid into the cylinders to soften the deposits may lay down your rings in the piston from overheating
Old Jun 7, 2013 | 08:42 AM
djsimm89's Avatar
in going to put a new headgasket on and re install the head it was filthy cleaned it out as well as all the deposits in it will compression test it again once i slap the head back on i doubt the results will change tho
Old Jun 7, 2013 | 12:14 PM
Pippen_001's Avatar
You should warm up the engine before measuring your compression. Also push in the gas pedal to open up the throttle body while cranking the engine.. That's how you should measure it.
94_civic_tuner
Oct 10, 2007 02:00 PM
turbo_ef4
Feb 17, 2006 11:55 AM
racingant
Dec 6, 2005 08:03 AM
mick
Jun 7, 2002 07:43 AM
