type S intake manifold on h22a4
Old Jun 4, 2013 | 08:29 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default type S intake manifold on h22a4
sorry if this has been done but i cant seem to find info on what kind of mods
i will have to do to get my type S intake manifold to work properly on my h22a4 head
not sure what vacuum lines are different or sensors (or lack there of)
Old Jun 5, 2013 | 10:39 PM
Sparksman's Avatar
Default Re: type S intake manifold on h22a4
I have the euro-r intake, so Im going to take a guess there similar minus the 3-pin IACV issues. If you have a PDE head you should be fine, to make a PDE intake fit on a P13 head you have to cut the tips off of the mounting flange for clearence to mount flush. I had to get a adapter plate for my euro-r's IACV, jdm-to-usdm "3 holes to 2 holes". They also have a special jdm screw intake temp sensor, but those should work fine on usdm wire harness if the type-s has it too.
I dont think the vacuum lines would be any different... If theres extras just plug them, if you need some just drill and tap a small hole on the backside. Aluminum is super soft, a regular drill and a metal bit will chew right through it. Then just screw in a copper hose piece. Just do a good clean up so theres no metal bits being sucked into the engine.
Heres the link to Rosko Racing's web page where he talks about modding the euro r to fit, maybe it might help you. You dont have the air holes by the injectors though. http://roskoracing.com/TechBlog/?p=87
civicdude00
Aug 4, 2007 09:35 AM
THEUSED
Jan 28, 2007 09:04 PM
StreetRacnGsR
May 24, 2003 10:56 PM
electbluesi
Aug 26, 2002 01:41 PM
migo
Jun 3, 2001 01:30 PM
