00 coupe offset
Old Oct 23, 2002 | 08:01 PM
020's Avatar
020
that's no moon
Default 00 coupe offset
what is the offset on the 4cy wheels for a 00 coupe?
will these fit? Thanks. https://honda-tech.com/zerothread?id=310558
[Modified by Icedmocha, 5:01 AM 10/24/2002]
Old Oct 29, 2002 | 08:37 PM
acorn4life's Avatar
Default Re: 00 coupe offset (Icedmocha)
no sorry they wont fit the offset for a 2000 accord is 42mm and the bolt pattern is 4x114.3 so.......
Old Oct 30, 2002 | 05:09 AM
jweller's Avatar
Default Re: 00 coupe offset (acorn4life)
bolt pattern is wrong so they won't fit.
+40 offset is about the minimum you can get away with on a plus sized wheel, and even that is pushing your luck. +42 is better. something like a 17 or 18 would need to be about +45 or +48 to avoid rubbing.
[Modified by jweller, 9:10 AM 10/30/2002]
rare Ek
35
May 21, 2007 12:36 PM
CardDealer
Nov 15, 2005 01:18 PM
rota power
Nov 14, 2005 08:42 PM
020
Feb 20, 2003 08:45 AM
Mr. Vapor
Jun 4, 2002 02:09 PM
