EF A/C Compressors!!
Old Jun 4, 2013 | 03:44 PM
Deetz's Avatar
Crazy Honda Guy
Default EF A/C Compressors!!
Quesation- my 89 crx si currently has a Matsushita a/c compressor, and has worked fine in the past. With most b series swaps, people who want to retain the a/c, often buy a conversion bracket that allows them to use a d series compressor on a b series engine!
I now have an Innovative a/c mount bracke, BUT, it is made for Sanden compressors.
Can i just buy the other style? Will my lines attatch the same way, correctly?
Thanks!!
Old Jun 4, 2013 | 06:38 PM
Chi925's Avatar
Default Re: EF A/C Compressors!!
As far as I know, the AC lines mount differently on the Sanden and Matsu compressors. The Lines are also routed differently. Was looking for a Matsu compressor at the junkyard a couple of weeks ago and came to the conclusion a Sanden would not work
Old Jun 5, 2013 | 06:58 AM
cn_bb's Avatar
My A/C setup on 90 DX hatch with LS swap:
- keep the original B series A/C
- Get the integra (90-93) A/C lines ends ( from JY)
- upper line fits perfect from the firewall to A/C ) .
- take off the lower line end from your car ( you just need the part from the radiator to the A/C end, you might need to drop the front bumper for more easy to work on), measure the length and figure out its shape
- Now you have the line with 2 aluminium ends , which bolds on radiator and A/C ends , you just need to custom on the A/C end only by extend the midlde rubber part, and replace the A/C end with the Integra's (it costs me about $40.00 from the profectinal hoses custom)
- it works perfect on mine !
PM me for Qs,
good luck !
Old Jun 5, 2013 | 02:09 PM
Deetz's Avatar
Crazy Honda Guy
^^ Amazing information, exactly what will help me out, thank you.
I guess my onnly question now is, which b series compressor do i need, or are they all the same? I have access to many different generations, so it would be good to know
Old Jun 5, 2013 | 02:44 PM
jonGSR's Avatar
Hasport's EF AC bracket works with the matsushita compressors. Sell your Innovative and buy the Hasport.
Old Jun 5, 2013 | 04:10 PM
M3THTICAL(EF)'s Avatar
Sorry to jump in but will any d-series compressor work with an 89 si?
Old Jun 6, 2013 | 05:32 AM
cn_bb's Avatar
we need someone to verify this !
Old Jun 6, 2013 | 05:37 AM
M-benz's Avatar
how about comparing the part number btwn the two ? just a thought here....
Old Jun 6, 2013 | 07:03 AM
zrickety's Avatar
There are at least 2 types of D-series ac compressors, and they are not interchangeable.
Deetz- I have a GSR compressor on my B16, it's a Denso. I would recommend getting a compressor designed for R134a so there are no conversion issues. The P72 and PR3 brackets are the same. Take the newer hoses and your old Matsushita hoses to a hydraulics shop. They can make the hybrid hoses. This is the route I went and has been working well.
Old Jun 8, 2013 | 12:47 PM
Deetz's Avatar
Crazy Honda Guy
I just want to thank you guys for the heads up with the information so far. I got the chance to hit up a junk yard today, and bought the DA Integra lines for $15. When the car comes back from paint, and i get everything together, i'll see exactly what needs to be modded. I will try and provide pics for others....thanks!!!!
camoxiong
Aug 14, 2014 01:51 PM
1sikhatch
15
Aug 12, 2010 01:51 PM
Tensa_Zangetsu
Sep 4, 2008 05:46 AM
Heylookits shawn
Sep 15, 2004 04:55 AM
