d16z6 coolant bypass for aftermarket throttle body help! with description
Old Jun 4, 2013 | 10:38 AM
waynesumner's Avatar
Default d16z6 coolant bypass for aftermarket throttle body help! with description
I know this is not the correct way for it to be connected but this is how mine is hooked up. I need help with how to bypass the fitv for an aftermarket throttle body I think I know how to hook it up but what do I do with the upper nipple on the manifold and smaller nipple on the thermostat that is looped since the aftermarket intake manifold does not have the top nipple?
Old Jun 4, 2013 | 11:09 AM
Joshka89's Avatar
Default Re: d16z6 coolant bypass for aftermarket throttle body help! with description
SO this is how yours is done now and you're going to completely bypass the fitv?
But you already know how to do it?
If your intake doesn't have the right connectors it's not going to work on your car.
Old Jun 4, 2013 | 11:21 AM
that's how it will be hooked up with aftermarket throttle body and intake manifold.
Old Jun 4, 2013 | 11:58 AM
grumblemarc's Avatar
The Grumpiest
Why is this here twice?
Old Jun 4, 2013 | 01:45 PM
the first one shows how mine is currently hooked up, the second is how im going to hook it up with an aftermarket throttle body and intake manifold. the reason for the second one being posted twice is because i had to show where the iac line went but it is off now soo. is this right or not?
Old Jun 4, 2013 | 01:50 PM
The Grumpiest
No. Why did you create two separate threads?
Old Jun 4, 2013 | 02:08 PM
i left some things out in the one, ive actualy got like 3 threads on this subject. i cant get the right information and the people that do give me relevant info doesn't make sense. i found my lines are not connected right so i figured out the way they connect and now i just need to figure out if im connecting it right.
Old Jun 4, 2013 | 02:17 PM
Old Jun 4, 2013 | 02:18 PM
n/a2boost's Avatar
I told you the right way to do it on the other fourm.
Old Jun 4, 2013 | 02:20 PM
The Grumpiest
Yeah. You'll get WAAAAY more help spamming the forum and insulting the people trying to help you.
Old Jun 4, 2013 | 02:55 PM
and you troll the ones who make honest mistakes, way to go!
Old Jun 4, 2013 | 03:24 PM
Ryank327's Avatar
You don't need to make multiple threads on the same topic and clog up the forums. Make one thread and stick to it. I don't know if you noticed the edit post button on every one of your posts or not but you can edit them instead of wasting peoples time and constantly reposting the same junk when it's been answered.
johnny-bravo
19
Sep 4, 2018 02:20 PM
KHANV1CT
May 9, 2014 08:13 PM
TyeJ23
Aug 31, 2005 07:52 PM
