Aftermarket D15 head gaskets with reinforced hot spot?
Old Jun 4, 2013 | 10:10 AM
fragmare's Avatar
Default Aftermarket D15 head gaskets with reinforced hot spot?
Does anybody have a list of aftermarket head gaskets that have the reinforced hot spot for D15 engines? I know Fel-Pro's Permatorque MLS line is reinforced. Not sure about the lower-end Fel-Pro HGs. How about DNJ, Beck/Arnley, etc.? Are any of those reinforced as well?
Old Jun 4, 2013 | 10:12 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Aftermarket D15 head gaskets with reinforced hot spot?
hotspot? why not a resurface and use copper sealer?
Old Jun 4, 2013 | 10:21 AM
fragmare's Avatar
There's a known hotspot in D15 engines between cylinder 2 and 3 due to a missing coolant vein. It was/is an engineering issue. I think Honda might have even put out a bulletin about it at some point. Anyway, it has a tendency to cause new (un-reinforced) head gaskets to go bad after 100k miles or so. Some aftermarket head gasket manufacturers (Fel-Pro does for sure) have since reinforced their head gaskets at this spot to help prevent failure.
Old Jun 4, 2013 | 10:31 AM
DumpdEJ6's Avatar
I like the tuna here
I don't think I would even mind if an aftermarket head gasket went bad after 100K lol. That's a lot of driving, regardless.
Old Jun 4, 2013 | 11:13 AM
fragmare's Avatar
lol true. though i might be mistaken about how long it takes them to fail.
Old Jun 4, 2013 | 05:21 PM
murphy95si's Avatar
I think cometec hg are reinforced
Posted from Honda-tech.com App for Android
slomovr
Jan 16, 2009 12:28 PM
new_climber
12
Jan 13, 2009 09:08 AM
Br1t1shguy
Dec 16, 2006 07:27 PM
filetofit
Aug 13, 2002 08:49 PM
