tuning/break in
Old Jun 3, 2013 | 10:57 PM
jhotboy2nv's Avatar
Default tuning/break in
i have a brand new ls vtec build new rings main and rod bearings arp rod bolts and arp hed studs skunk 2 cams intake manifold and throttle body rc 310 injectors etc.... so here is my issue my car is running extremely rich im using a stock computer for now.. is there anyway i can get a base map in the meantime to just break in the engine or do i need to dyno it........ im very confused and idk wat to do i dont wanna damage my motor
Old Jun 3, 2013 | 11:15 PM
doood's Avatar
been there done that
Default Re: tuning/break in
how many threads do you need asking this same exact question?
Old Jun 3, 2013 | 11:22 PM
NZXTInerTia's Avatar
22 obviously.
Old Jun 3, 2013 | 11:38 PM
jhotboy2nv's Avatar
yo listen dood or w.e hop off ma **** man... if im posting its to obviously look at other ppls point of view... if u dont like it stop coming on my thread acting like ur the admin and ****
Old Jun 4, 2013 | 12:17 AM
holmesnmanny's Avatar
You can't use a stock computer on something modified like yours obviously. Just call around and get a hold of a tuner after picking up a chipped ecu.
Old Jun 4, 2013 | 05:57 AM
doood's Avatar
you've probably already caused irreversible damage to you engine by driving untuned on a stock ecu.
you should have probably asked these questions BEFORE you put the motor together. always surprises me how people never learn and do their due diligence until after the fact.
Old Jun 4, 2013 | 06:50 AM
mechanix619's Avatar
How long have you driven the car under these conditions? If everything was fresh and you drove the car with it running super rich you've probably done a little damage to the sleeves/screwed up the cross hatch. The excessive fuel coats the cylinders and washes away all the oil, because your rings haven't seated yet its possible they never will now. This is worst case scenario.
At the very least, stock injectors should've been used.
turbohatch96y7
Feb 11, 2015 09:14 PM
stevenDAtegra
Apr 20, 2009 01:24 AM
b16a4
Dec 11, 2007 05:58 PM
toEknEEg
Aug 11, 2005 09:57 PM
