Honda S2000 Honda S2000
S2000 Short Block for Sale. 5,000 Miles
Old Oct 23, 2002 | 07:42 PM
MiXeD Up CiViC's Avatar
Default S2000 Short Block for Sale. 5,000 Miles
I got a 2001 Honda S2000 F20 Bottom End. This block had 5000 miles on it when taken out of the car. I got this from a friend at the honda dealership because a customer who was a friend of a mechanic there got a replacement block instead of getting this one rebuilt. It comes with pistons, rods, oilpan, crank. Everything from deck down. This has not been taken apart yet either. 2 of the cylinder walls are slighty scorgerd but you can porbbaly get away with just honing the block out or u could even have it bored for bigger pistons. WIll ship at buyers cost. Email me at Hondacrew13@aol.com with offers.
Old Oct 24, 2002 | 11:08 PM
profpin's Avatar
Default Re: S2000 Short Block for Sale. 5,000 Miles (MiXeD Up CiViC)
Wow sounds like a good deal ....
How much for the short block?
Old Oct 25, 2002 | 10:40 PM
Default Re: S2000 Short Block for Sale. 5,000 Miles (profpin)
make me an offer and we can go from there.
Old Oct 26, 2002 | 06:48 AM
coquinn's Avatar
Default (none)
You can not bore the cylinder walls on an S2000 due to the materials used to make the sleeves for the block.
Old Oct 28, 2002 | 09:18 PM
profpin's Avatar
Default Re: (none) (coquinn)
Why not ? Isnt it the same material as the prelude motor?
Old Oct 29, 2002 | 10:12 AM
coquinn's Avatar
Default Explanation
Overboring the engine would not be too easy because Honda wanted to make the engine very compact, hence the F.R.M. cylinders. You would have to resleeve the engine with ductile iron; even then you could not get much more than a 1.00mm -2.00mm overbore. 2.00mm would get you an increase in displacement of about 90.00cc - which really is not worth the money and time involved.
I suppose you technically can overbore the engine ...so my previous statement was incorrect.
Old Oct 29, 2002 | 03:40 PM
You most likely would not even have to overbore the block because the scratches are not that bad. just a good honing would work fine. really need to get rid of this so let me know your offers. thanx and i will ship this out.
Old Oct 29, 2002 | 04:42 PM
cjb80's Avatar
With out saying too much, there are certain things about the F20C motor which are different from other Honda motors.... It wouldn't be a good idea to bore this motor out, it's possible, but chances are you'll waste alot of time and money figuring out how to do it right.
Chris
MrJDM_
Apr 4, 2013 03:48 PM
bb_one
Aug 9, 2005 07:25 PM
hondamanwill
Honda S2000
Sep 1, 2004 10:20 PM
