Ek4 Sedan won't start (EU Model)
OKay, to make a long story short.
My ek4 has not been started for a couple years (was put away perfectly running) and i wanted to make it run again, but it does nothing except for all the lights on the dash on IGN2.
it is running a p28 with hondata s300 so immobilizer should not work ?
Symptoms :
Fuel pump is not priming.
Starter motor is not turning over.
i do hear the main relay click once when put in IGN2
The green Key Light is flashing when put in IGN2
engine checklight goes out after 2 secs as it supposed to.
No faults on any of the sensors.
the following has been checked.
New battery giving 13V
Main Relay has been checked
no power to fuel pump on IGN2.
All grounds have been checked.
tried a new P28
tried the original p30
Please advice as i am out of idea's
Symptoms :
tried a new P28
Have you gone over all of your fuses making sure they are still good? Be sure to check the fuel pump related ones especially. If all your fuses test out to be good I would suspect your fuel pump needs to be replaced.
Yeah something is up with the fuel pump. See if you can pull it and check it, then replace it.
Not cheapest but if it isn't getting power and everything up front is good then it should be that
civic08
Mar 14, 2010 09:26 AM
