1993 Del Sol Manual?
Is there a 93 hanes manual online for free? I need it but I'm really tight on money and need it all for the parts.... I have a 93 del sol si but it has a d15b, so idk if I would use si book or s.
Would the ohms reading for sensors and **** like that still be the same? Cause I'm trying to check all my sensors and need the right ohms. That and for the fuel pump cause I think that's why I'm getting CEL 43.
Yes. The Haynes manual for that year of civic should be the same engine. The engine is the important part.
Mine comes with a D16Y8 which is exactly what the 1998 Honda Civic EX has. That manual for 96-200 is perfect for me.
That or the 92-96 would be what you'd want for the 95 Del Sol.
http://www.haynes.com/repairmanuals/honda/civic
Just look in the front for the table on contents and you'll see the engines listed, if it matches yours, get that manual
Alright now I just need to find a copy online so I don't gotta buy >.<
That manual prob easier to find rather then the actual del sol one, so I'm gonna do some google searching.
Thanks.
Thanks.
Yeah AFAIK there isn't one specifically for the del sol, not that i could find.
I won't tell you to go to a torrent site because i'm sure there's a rule against that.
You might be able to google a pdf.
You could also go down to autozone and see if they have the numbers you need in a database, or find a friend who has the manual.
If you're really desperate I could mail you mine, I won't be needing it
qat727
Feb 28, 2006 08:57 PM
