Spark plugs are full of oil
Starting about a month ago, my car would start and shake a little until it really took off. I figured this was because of the spark plugs.
A couple days ago, I pulled the spark plugs and they were full of oil. The car overheated for less than a minute, I put antifreeze in it and it was fine.
The check engine light came on saying cylinder #2 was misfiring.
Does this sound like a replacement of spark plugs and valve cover gasket or blown head gasket?
If its anything like the F22 engine in by CB7 accord, there are o-rings that sit on the bottom of the spark plug tubes between the rocker arms i believe. They will get brittle and fail overtime, letting oil in. This usually occurs starting at cylinder #2 since there is an oil passage right next to it. If you check on lower spark plug tube seals/o-rings it should take you to where you need to go.
I ended up replacing the spark plug wires since they weren't making a good connection. My valve cover gasket was loose. Back in business. $50 bucks later I'm back riding better than ever!
I've also found that tightening the valve cover bolts will sometimes do the trick, they can vibrate loose.
If it is actually the o-rings, bear in mind that there are actually two sets of seals that keep oil out of the spark plug wells, the valve cover o-rings, and another set below the rocker-arm cage (just like Merault says....). If you clean out the wells really well, you can sometimes see if it's the upper or lower seals which are leaking after a few miles by tracking in the wells.
The upper are simpler to do, try those first if you can't see which ones are leaking and if they don't solve the problem, you have to pull the rocker arm cage and replace the lower ones.
This video gives an idea (his torque values -among other things, are questionable, but it gives you an idea if you're doing this for the first time):
I replaced the spark plug wires and after driving a lot today the car is doing MUCH better. No issues whatsoever. Well, minus getting into a car accident about an hour ago. Sitting at a night and the big dodge ram in front of me decides to put it in reverse this hitting me.
Just sometimes best intentions can lead to headaches (https://honda-tech.com/forums/honda-accord-1990-2002-2/oil-spark-plugs-stripped-bolts-etc-3149946/), and it might have been a simpler fix that would have sorted it....
92 accord lx coupe. Still got stock tranny, replaced clutch and various other maintenance things. Nothing has really broken on me, but ive replaced things with preventative maintenance.
Up until then the engine/tranny have been so solid, a couple of clutches and EGR port cleaning, but other than that typical Honda goodness.....
lol Dan, I like how you say he probably found the problem, no offense to me, then proceed to tell him to keep an eye on it since he may still have a leak. Kinda funny.
I've had 4 cb7s and all have had rocker arm spark plug tube seal leaks by 225000 or less.
The OP doesn't give any idea how many miles he has. I was just giving out as much advice as could be helpful.
Yep, he coulda found the problem, but he may not realize it til it leaks and the spark plug wires pull apart has happened to me before.
Victor Jónsson
12
Apr 18, 2013 10:31 AM
