ecu question
I have a 96 civic ex with a jdm b16a swap. It has obd2 dizzy, alternator, everything besides injectors. They are obd1. The motor is stock besides an itr header, full exhaust, injen short ram intake. Can I run an obd1 p30 ecu and be good to go?
Have you read anything like this?
http://hondaswap.com/hybrid-eg-ek-dc...6a-ecu-275661/
Obd2 injectors,alt and dizzy work just like the obd1 version,only difference is the plugs. So yes you can use and obd1 ecu. You just need an ecu jumper harnes from obd2a to obd1 and and obd1 ecu. If the ecu is not ment for a b16 then it will need to be chipped and tuned.
2.2 teg
Oct 20, 2005 08:21 AM
