'96 Honda Starts and dies.
Old Jun 2, 2013 | 03:25 PM
ConfusedHonda's Avatar
Default '96 Honda Starts and dies.
Every time I try and start my '96 Honda Accord, it will start and automatically die. I've tried replacing the Ignition Switch, Main Fuel Relay, Spark Plugs, and Distributor, however it continues to do this.
Old Jun 2, 2013 | 11:04 PM
holmesnmanny's Avatar
Default Re: '96 Honda Starts and dies.
How does the lock cylinder work and act ? That's the round cylinder thing you put the key into. I assume you didn't replace that either ? Make a good quality video of you starting it a few times.
Old Jun 5, 2013 | 07:48 PM
The lock cylinder is in good condition and works normally.
Old Jun 5, 2013 | 08:11 PM
ReaperMan's Avatar
are you sure? try starting it and when it starts hold the key in the same position when it started and keep holding it if it doesn't die then its your tumbler
Old Jun 6, 2013 | 02:00 PM
I tried that a few times, and it still died.
Old Jun 6, 2013 | 03:24 PM
ReaperMan's Avatar
so that is ruled out. try fuel pressure better yet put a multimeter to the black/yellow wire back at the pump access panel and have someone start it and see if voltage varies or stays steady if voltage remains steady check fuel pressure if fuel pressure rules out check injector pulses see if anything is abnormal on the test light the way it lights up should be a steady pulse , check ohms on each injector with the injector connector off the injector. then check for compression and leakdown test, then move up to spark plugs cables cap and rotor maybe even ignition coil you can have the icm and ignition coil tested at autozone etc. when was the last tune up? fuel filter maybe too clogged and die at initial startup, main relay. post all your results and we can help you futher
Aaron Weise
Jul 9, 2018 09:19 AM
nativmd
Honda CR-V & Element
Feb 23, 2013 07:54 AM
chickendance
Mar 12, 2012 03:48 PM
03PackEngr
Feb 25, 2008 05:11 PM
toyorotor
Jun 13, 2005 01:31 PM
