99 DX will not crank.
Re-did my main grounds sanded and all that. the battery is good lights stereo and such works. But when I go to try and start it nothing....just a click from the main relay every time I turn the key to crank it fuel pump primes no codes hit the starter a few times. The car worked fine all I did was unclip the dizzy inspect cap+rotor plugged everything back nothing....353,xxx KM's bone stock Y7 this is my winter car so it needs to be started and ran every-now and then input appreciated.
Have you checked all your fuses under hood and the ones in your under-dash fuse box? Double check them and check your green 40 amp ignition fuse in the engine bay fuse box. Also check your battery cables for tightness, and can the car be bump started?
Will go over all fuses in bay box and underdash. I don't have any hills near where I live. may remove the starter and inspect tomorrow. I have a 94 GS-R anyone know if that starter will work on my DX both M/T
CRX7
Aug 29, 2005 01:42 PM
