B18c engine swap no start
Just finished installing my engine in my 99ek and no start, there's fuel but no spark
I'm using my 99 ex harness and stock p2p ecu
My engine is 96 Jdm b18c type r, are the distributor plug the same on these cars, it plugs in perfect just wondering if I have to require the distributor
Both are odb2 distributor
The dizzy plugs are different from 99-00 sohc to 96-98 and 99-00. The 99-00 sohc uses an 8 wire plug and the 96-98 sohc and 99-00si uses a 10 wire plug.
It could be the ecu that is not letting it start.
When I plugged the distributor to my harness is plugs in ok except there is 2 extra wires that's not connected
Thanks you guys I can finally sleep again
I work at a Hyundai dealer and did my engine swap in the shop my car is been on the hoist for 2 days did not want to push it out
whyS0serious
13
Jan 12, 2015 06:20 PM
90Rexx
Oct 28, 2008 12:46 PM
GOLDBERG
Jun 20, 2005 02:31 PM
