POST YOUR CLUTCH STOPS
Old Jun 1, 2013 | 02:21 PM
67mmlsv's Avatar
Default POST YOUR CLUTCH STOPS
hey i just recently bought a new comp twin disk and need ideas on a clutch stop, post pics or info on how you guys did it.
this is pretty nice , i dont think any honda guys use this method but it might work
Old Jun 1, 2013 | 03:11 PM
92redhatch's Avatar
Default Re: POST YOUR CLUTCH STOPS
I wish someone would have showed me that one when I had my honda. I just had a nut welded on the pedal with a bolt thru it
Old Jun 1, 2013 | 03:19 PM
67mmlsv's Avatar
yea i was thinking of that too
Old Jun 1, 2013 | 03:25 PM
67mmlsv's Avatar
maybe this one , only 10 bucks on ebay
Old Jun 1, 2013 | 04:30 PM
SPOOLINmatt's Avatar
adjust the pedal down. Free.
Old Jun 1, 2013 | 04:34 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
how do you know know how much is too much travel?
Old Jun 1, 2013 | 05:11 PM
tepid1's Avatar
When you trash thrust bearings or stall the car when you push in the clutch. lol
Old Jun 1, 2013 | 05:31 PM
haha. You want it to engage just a little after you start moving the pedal out. Its a common sense kind of adjustment.
Old Jun 1, 2013 | 06:22 PM
90blackcrx's Avatar
Remove clutch switch.... insert bolt and thread in to desired stop... done.
Old Jun 1, 2013 | 09:21 PM
civic-r11's Avatar
So u basically adjusted the clutch pedal to the ground almost then?
Old Jun 2, 2013 | 05:12 AM
Turbo-LS's Avatar
There are instructions with the clutch or should be but turn the car off. With two people one pushing the car and you pushing the pedal slowly push the pedal down until the car starts to roll. Add 1/8-1/4" more travel and that's where the clutch needs to stop. That's best way to describ it that's what my Tilton instructions said to do years ago.
This time around with my clutch masters fx700 before welding a stop to the pedal or floor I adjusted the clutch pedal travel on the master cylinder and was able to adjust mine that way and no need a pedal stop but not all cars/ clutches are the same
If I needed a pedal stop i would have drilled a hole in the floorboard, welded a nut to the floor, put a second nut on a bolt and screwed the bolt into the first nut on the floor and used the second nut as a locking nut to hold the bolt in place so it would always have adjustability
Old Jun 2, 2013 | 05:20 AM
evilone's Avatar
Attachment 324542
That's not a pedal stop, it's used to prevent the clip from popping out of the throw out bearing on a pull style clutch
Old Jun 2, 2013 | 05:52 AM
Turbo-LS's Avatar
But theoretically you could stop the throw out fork travel which would be the same as stopping the pedal travel distance.
Old Jun 2, 2013 | 06:24 AM
good luck with that type on a B
Old Jun 2, 2013 | 06:25 AM
it doesnt feel that way once done.
Old Jun 2, 2013 | 08:15 AM
civic-r11's Avatar
Ok.. I just trying to figure outnhow exactly to do this cause im on a cc twin disc.. and trying not to ruin it.. so adjusting the clutch until the engagement is kind of almost to t he floor..meaning since I not putting a stop.. getting it closest to the floor with engagement is best?
And I was there at show down and saw your crank pulley come off. Sry to that happened. . Cant believe import experts won it.. lol. Cause of the rain out.. lol
Old Jun 2, 2013 | 08:59 AM
Turbo-LS's Avatar
Yes that's how you adjust it. There may not be enough adjustment though and then you will need a stop
Old Jun 2, 2013 | 10:20 AM
92redhatch's Avatar
If your not using the clutch switch for full throttle shift remove it and put a bolt thru it. That's the easiest way of doing a pedal stop.
Old Jun 2, 2013 | 10:22 AM
TwinScrolled's Avatar
We just welded a nut to the pedal. Here's what it should look like getting installed. Hahaha
Old Jun 2, 2013 | 03:08 PM
ON-DA-EDGE's Avatar
Putting a bolt through the clutch switch hole is the WRONG way for a clutch stop...you dont want to push the throw out bearing into the pressure plate..
Old Jun 2, 2013 | 04:59 PM
tepid1's Avatar
Huh?
Old Jun 2, 2013 | 05:23 PM
itspools's Avatar
I believe the pic the OP posted is of a EVO trans anyways and that piece is to stop the clutch fork from coming back too far/too fast and causing the snap ring to pop loose since they use a pull style setup.
EDIT: Didn't realize this was already pointed out in post #12.
Old Jun 2, 2013 | 05:42 PM
tepid1's Avatar
That's exactly what it is. On quick and hard shifts the clip comes off.
Old Jun 2, 2013 | 06:38 PM
92redhatch's Avatar
Huh?
Old Jun 2, 2013 | 07:52 PM
67mmlsv's Avatar
yea huh ,, the throwout bearing pushes onto the pressure plate, thats what its supposed to do
