specs, setups, and run-down on h-series vtec motors.
Old Oct 23, 2002 | 06:53 PM
dfoxengr's Avatar
Default specs, setups, and run-down on h-series vtec motors.
i need almost all the specs, and prices of complete swaps youve seen. goin in a 92 hatchback and wondering if theres many differences as i plan an all-motor engine. i will sleeve and bore it and be running around 12.0:1 compression. some setups and specs would be good. and links. also the trannys, mostly interested in the LSD ones (LSD comes on all JDM ones right).
last, is the 20 HP increase from the jdm h22a type-s over the regular jdm h22a due only to the compression increase (11.0:1/10.6:1). just list all differences you know of between mainly the longblocks. thanks
[Modified by hybridvteceg, 11:04 PM 10/23/2002]
Old Oct 23, 2002 | 06:56 PM
Jonathan_ED3's Avatar
Default Re: specs, setups, and run-down on h-series vtec motors. (hybridvteceg)
http://www.h22a.org
If you want to know some bad A N/A setups, talk to Prospeed..he's the man
Old Oct 23, 2002 | 06:59 PM
TimeRacer's Avatar
Default Re: specs, setups, and run-down on h-series vtec motors. (hot_EG)
Unless you're planning to do a lot of work to the engine before putting it in go with the B20 VTEC. They're a little bit ligher and seem to be more modification friendly.
Old Oct 23, 2002 | 07:05 PM
dfoxengr's Avatar
Default Re: specs, setups, and run-down on h-series vtec motors. (TimeRacer)
original plan was 86 mm x 89 mm LS vtec, just bigger than b20vtec, but considering this option.
H23_Del Sol
Jun 20, 2006 08:05 AM
casmello
Jun 21, 2005 08:05 AM
H23preludeSi
Jun 6, 2004 05:51 PM
KS-R
Jan 26, 2003 06:26 AM
Romulus
Sep 18, 2002 09:20 PM
