D16y8 block with d16z6 head
Old Jun 1, 2013 | 09:45 AM
Syke909's Avatar
Default D16y8 block with d16z6 head
Like the title says I have a y8 block and a z6 head all stock and wanted to know what was need to make it run right in my 91 hatch. I'm also using my si intake manifold. A parts list would help out a lot.
Old Jun 1, 2013 | 06:08 PM
Syke909's Avatar
Default Re: D16y8 block with d16z6 head
Also the Block and head are split so I also wanted to know what would be needed for them to work properly
Old Jun 1, 2013 | 07:01 PM
90_EX_Civic's Avatar
umm... pretty sure if you look in the FAQ, there is a write up on how to do this type of head swap. it's basically a mini me.
then look up how to convert your obd0 car to obd1.
it's all in the FAQ
Old Jun 1, 2013 | 11:15 PM
Honda.Si's Avatar
Non vtec engines have oil control jet on the block located between head and block vtec engines the oil control jet is in the head. So a d16a6 head and y8 block equals No oil control jet. Combo will still work but why not just get a y8 vtec head? Wont have to deal with making sure the compressions right and probably a different timing belt. Good luck tho bro!
Old Jun 1, 2013 | 11:20 PM
Honda.Si's Avatar
My bad its late just noticed you have a z6 head not an a6 so forget i said that
youryanyou
Aug 24, 2021 02:42 PM
ZCcivicBOI
Nov 23, 2007 06:41 PM
trbodelasol
Apr 2, 2005 07:48 PM
xci_ed6
Dec 13, 2004 09:57 AM
