What OBD is my B16A SiR-II?
Old May 31, 2013 | 07:50 PM
DennisEM1's Avatar
Default What OBD is my B16A SiR-II?
Hi there guys, I have an EM1 with a B16A SiR-II swap in it from a same-gen JDM Civic SiR. I need to order a new VTEC Solenoid gasket for my little leak and was wondering what OBD my B16A SiR-II is. Looking on Wikipedia, the specs say it's an OBD1, but on some this other thread here on Honda-Tech, the guy says that it's an OBD0 and that I should use the gaskets from a 90-91 NSX (Part #36172-PR3-005). Which is correct and which part do I buy?
Old May 31, 2013 | 08:00 PM
jdmcivic23's Avatar
Default Re: What OBD is my B16A SiR-II?
u have an obd0 motor i have the same one that i pull out of my ef si to put in my eg 4 door. not sure about gasket though.good luck.
Old May 31, 2013 | 08:04 PM
DennisEM1's Avatar
Thanks for the tip, but are you sure though? I'm still quite confused and I looked at this website over here http://www.jdmenginedepot.com/jdm_en...mission,_&_ECU and there are specifications indicating that it's an OBD1 motor. Everyone I've seen on the forums have been saying it's OBD0, but on specs from other websites, I've seen it as OBD1. I mean I can always buy two gaskets and just return one, just to see, so maybe that's what I'll end up doing.
Old May 31, 2013 | 08:24 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Well, there are ways to tell if a motor is OBD0 vs. OBD1, aren't there? I mean, even the connectors are different, are they not? What ECU are you running? And ... what do you mean by "same-gen JDM Civic SiR"? If your EM1 is a 6th Gen Civic, wouldn't that mean OBD2a/b?
Old May 31, 2013 | 08:35 PM
DennisEM1's Avatar
Yeah I know there are ways to tell them by the connector, but I don't exactly have the car with me right now and I won't be able to see it for a few days. And I'm not exactly sure what ECU I'm running at the moment, haven't checked that either. And yeah my EM1 is a 6th Gen Civic, which was supposed to come with the OBD2B on the B16A2, but that's been swapped out.
Old May 31, 2013 | 09:07 PM
DennisEM1's Avatar
Nevermind, thanks a lot for the help guys. I just figured this out. Ended up asking the mechanic to check up on it and it is an OBD0. /closed
Old Jun 1, 2013 | 09:04 AM
jdmcivic23's Avatar
W O W!!!!!!!! HEY GOOD LUCKY.
Kuhniee
Mar 5, 2010 09:24 PM
patwitahonda
Jul 31, 2009 07:52 AM
DaMmniTz
Jun 8, 2005 04:03 PM
b16crx0062004
Feb 4, 2005 11:02 AM
