High NOx Emissions
Old May 31, 2013 | 12:14 AM
Kouki-EK9's Avatar
Default High NOx Emissions
I have a 99 EK with a SOHC ZC engine. The catalytic converter and O2 sensor are not OEM and about 2 years old. Everything else is stock.
Any ideas what could be causing these results?
Thanks
Old May 31, 2013 | 04:19 AM
EsotericImage's Avatar
Retired Moderator
Default Re: High NOx Emissions
need more info!
Old May 31, 2013 | 07:12 AM
Kouki-EK9's Avatar
Originally Posted by EsotericImage
need more info!
Like what?
Old May 31, 2013 | 12:21 PM
steveeb's Avatar
Is your engine light on? If not O2 sensors should be working and it may be the cat again. Try using a bi-directional scan tool to check the real time voltages to the two O2 sensors. Make sure your car is warmed up and check the voltages. O2 sensor #1 (upstream/before cat) voltage should bounce around. O2 sensor #2 (downstream/after cat) should hold steady at 0.5ish volts. If #2 is bouncing around, it would indicate a bad cat.
Old May 31, 2013 | 12:29 PM
Kouki-EK9's Avatar
No, the check engine light is off. I was looking at those voltages the other day but had no idea what they were supposed to be. Thanks, I'll check them again.
Old May 31, 2013 | 03:38 PM
tlarimer's Avatar
I would do as Steve said and check the voltage of the O2 sensors. I have had trouble getting aftermarket/high flow cat's to pass emissions in the past. Numbers that high typically indicate a bad cat though.
Not sure how close to Murrieta you are, but I have some spare OEM O2 sensors from a 99 D16Y7 that I keep as back up's just in case, you are more than welcome to borrow one or both if you need.
Old May 31, 2013 | 04:07 PM
grumblemarc's Avatar
The Grumpiest
Is it a real catalytic converter or one of those Ebay test pipes (aka hi flow cats)?
dwf2096
May 12, 2008 03:56 PM
silentdeath12886
Feb 13, 2007 11:43 AM
bbhockey19
Oct 31, 2006 04:03 PM
sfgiants11
Jun 5, 2005 07:22 AM
