Honda CR-V & Element 2WD & 4WD Element & CR-V
Crv door components keep cutting out
Old May 31, 2013 | 12:08 AM
Infinity_Racer's Avatar
Default Crv door components keep cutting out
Anyone ever run into this issue? My 99 crv front passenger door's electronics (speakers/power window) cuts off randomly. I'll open the door and the things will work again. I peeled back the rubber boot for the harness and don't see any issues with the wires. I think it's the plug going through the boot/door because it seems loose but I'm not sure how to make that fit more snug. Any help would be appreciated. Thanks
Old May 31, 2013 | 03:15 AM
Sticker Bomb's Avatar
Default Re: Crv door components keep cutting out
It could be the plug. Open the door and wiggle the plug around and try using the window to see if it cut's it out. It could still be wiring that is harder to see that could be torn and touching each out. They don't put much wire there and over the years wires case drys out and will crack.
Old Jun 1, 2013 | 11:48 AM
blackskunk2si's Avatar
ive seen it happen in civics, the wires break at the molex plug that plugs into the door.
Old Jan 23, 2025 | 07:53 PM
Jayden Sinclair's Avatar
So I go 2000 rd1 manaul an swaped everything witeing looms an all an I seen drivers door plug was missing so I went an cut drivers door plug off a 1997 I just matched wires but I am left with 2 wires yellow an green an then blue an red ?
sikefcrx89
May 22, 2014 09:23 AM
dogbiscuit
Dec 27, 2013 09:11 AM
ctag
12
May 28, 2012 03:23 PM
ÁrniMkv
Sep 20, 2011 12:56 PM
bochincheboy3ek
Sep 16, 2010 10:12 PM
