FRESHLY BUILT B16A2
I have a COMPLETELY REBUILT B16A2!
-FRESH BOTTOM END
-PISTONS/RINGS/HONED/BEARINGS & BOLTS
-HEAD FULLY PORTED & MILD POLISH
-RESURFACED BLOCK & HEAD
-SUPERTECH VALVES/DUAL VALVE SPRINGS/TI RETAINERS/KEEPERS
-WATERPUMP/OIL PUMP/CAM SEALS/CRANK SEALS
-COMETIC MLS HEADGASKET
-ARP HEADSTUDS
-TENSIONER/RACING TIMING BELT
-TODA CAM GEARS & BOLTS
-OIL PAN GASKET/OIL PICKUP/OIL SEALS & MAIN SEAL
-VALVES ADJUSTED
-ALL OTHER RUBBER SEALS REPLACED
-WATER PIPE/O RINGS/AIR CHAMBER SEALS/T-STAT
-VALVE COVER SHAVED & POWDERCOATED
-VALVE COVER GASKET SET
-NGK SPARK PLUGS
$2500 OBO
CALL TEXT EMAIL 707-230-7658
WILL CONSIDER TRADES LET ME KNOW!
-FRESH BOTTOM END
-ARP HEADSTUDS
-VALVES ADJUSTED
-NGK SPARK PLUGS
$2500 OBO
Mhollaek9
15
Sep 13, 2007 06:02 PM
