93 d16z6- No dash lights along with running lights
Old May 30, 2013 | 04:17 PM
cams and draws's Avatar
Default 93 d16z6- No dash lights along with running lights
Hey there honda techs,
I must first day thanks for all the great work that yall have done. I have referred to this site for many of my own repairs and have not been let down yet!
I now have a problem that i can not find a solution for and am stumped. My 93 civic (d16z6 stock) will not turn on the dash lights or running light when i turn my selector **** on the steering column. The head lights come on, high and low beams, as well as the (i think they are called) cluster lights. My turn signals blink and my brake lights come on when i hit the brakes and the radio works.
I have checked all the fuses and they are all good and have taken the selector **** apart and cleaned and greased all the contacts. When i took the selector **** apart i checked for continuity between the plates and the males ends and all were beeping. I dont think this has anything to do with it but i recently had to buy and install a new ignition switch.
Thanks for all the help- cams and draws
Old May 30, 2013 | 04:18 PM
Default Re: 93 d16z6- No dash lights along with running lights
I have also tried to jump the dimmer switch and had no luck.
Old Jun 1, 2013 | 12:37 PM
fcm's Avatar
fcm
Old Fart
Check for power to the combination light switch and power out of it, on the park light circuit, as on most Honda/Acura the fuse is after the switch so you can also test for power at the fuse when park/head lights are on.
If no power at the fuse the combination light switch is bad.
If you have power at the fuse, the problem is the fuse box or dash illumination wiring after the fuse box, [red/black] maybe something not plugged in properly into the fuse box, [under dash fuse box]. 94
cams and draws
May 30, 2013 07:32 PM
onesoejourner
13
Apr 20, 2008 09:50 AM
Pabs626
Jul 17, 2007 10:25 AM
rob_dogg55
11
Nov 15, 2006 09:03 PM
NatedoggAZ
Feb 10, 2006 11:00 AM
