B21A1 Prelude motor swap into 91 CRX...........
Need to know basically how hard it is gogin to be and everything i need to do for it to go in. Plus any parts i need to change or get for it to run right. If anyone can help me i will greatly appreciate it.
I am doing this because everything is for free and i want to use it.
[Modified by BadWing10, 4:28 AM 10/24/2002]
the b21 is one of the B series that doesn't share the normal block of all other B series, isn't it?
Anyway...even if it does, why would you want to do that?
sorry....i'm a retard....someone can help Billy....
he got everything for free...and its all legit...so lets all help him
[Modified by hybridRhatch, 4:36 AM 10/24/2002]
not too hard, you gunna have to play "make the custom mounts" though...
if this puts you off, it may be pretty difficult...
teh engine is installed on a pretty weird angle in teh Prelude.
maybe take a look at a 88-91 Prelude engine bay and play "compare and contrast" with the current mounts in your CRX.
good luck!
t..
good luck!
t..
Even if you did manage to get that in.....you will now have what, 140 hp? Those B series motors from Honda are the oddballs. I should know. I have the B20a5 in my Prelude. I dog of a motor and runs out of breath before 7,000 rpm.
I like the 3rd gen Prelude body though.
You can check out my car at http://www.HondaPrelude.com
Set-up "Prelusions" 1989 SI Phoenix Red, non 4 Wheel Steering
This is a weld-in swap. Forget using Hasport mounts. Given the fact that the B21 is really not that great, I would forget about doing this swap.
stemiched
71
Aug 25, 2006 05:42 AM
Sci_v_icI
14
Mar 3, 2006 11:50 PM
