c12 or 112Octane? How far can it go?
Old May 30, 2013 | 03:08 PM
BoostedDOHCGSR's Avatar
10 Year Member
Default c12 or 112Octane? How far can it go?
I have a local facility near me that sells 112 octane fuel for about half the price of c16. Im wondering if anyone has used c12 or 112 and how far have they been able to push this fuel.
Old May 30, 2013 | 03:23 PM
RedDC2GSR's Avatar
Default Re: c12 or 112Octane? How far can it go?
what are you aiming for with your build. lay out the details and I'm sure you will get some good feedback.
Old May 30, 2013 | 04:50 PM
SPOOLINmatt's Avatar
itll go a long way
Old May 30, 2013 | 11:13 PM
10 Year Member
without getting into specifics. Gsr on boost.
looking for at least 600 out of 112. doable? or has it been done before?
Made over 600 on c16 no issues.
Old May 31, 2013 | 03:43 AM
seelback's Avatar
should be good. ive seen 530-545whp on 17-18 psi on 93 octane on a stock sleeve built b20vtec with a golden eagle block guard. so im sure 112 for your setup should be fine as long as its tuned well.
Old May 31, 2013 | 05:59 AM
xenocron's Avatar
What brand 112, is it sealed? Is it consistent...
Consistently getting the same fuel blend is the KEY unless you plan on retuning each time you order up new fuel
Old May 31, 2013 | 06:22 AM
people kill me with over doing stuff. We have done over 700 easily consistently on 110oct years ago.
Old May 31, 2013 | 09:01 AM
seelback's Avatar
has anyone on here tried using 100LL AVGAS. I use it in my lawn equipment, it loves it. I used it in my old d16 turbo setup at 10psi, it loved it and pulled harder when i used it vs 93 octane. my dad uses it in his 440 blown big block cuda running 10-12psi and never had a problem with, and my dad also uses it in his 13:1 compression hemi cuda race car and has no problems with it. Outside of me, my dad and a couple of other locals, i havent heard alot of using this fuel. im just wondering if anyone here on honda tech has done a write up on this fuel.
Old May 31, 2013 | 02:28 PM
Ive seen people use that.....im sure its consistent since it goes in things that leave the ground haha.
Old May 31, 2013 | 10:54 PM
10 Year Member
This is all the info I have on the Gas. Lmk if anything looks odd.
It is supposedly consistent and you can buy it sealed in a barrel or they can fill whatever container you take in from there steel drums they have out back. I am in Ca so 91 is our max pump and E85 is too far out of reach.
Old Jun 5, 2013 | 10:09 PM
10 Year Member
Old Jun 6, 2013 | 03:01 AM
Silent_Bob69's Avatar
I considered 100LL AVGAS as I live right beside a
municipal airport lol, but there's a filling station not too far from me that has a Sunoco 110 pump.
Old Jun 6, 2013 | 04:00 AM
seelback's Avatar
theres many mixed discussions about the octane rating of 100LL AVGAS. if i was not running e85 in my car, i would probably be running 100LL AVGAS, cause from my experiences and what i've seen, 100LL performed just the same as 110. i know true conclusions need to be backed up by dyno and track results with afr and timing graphs between each fuels.
Pullig
Feb 17, 2015 06:16 AM
xsxnosxsx
Honda Civic (2006 - 2015)
14
Apr 10, 2011 05:01 AM
rharris84
Jan 19, 2007 07:33 AM
Drum_Guru
Jan 9, 2004 06:28 PM
variablevalve
15
Dec 25, 2002 07:47 PM
