Honda CR-V & Element 2WD & 4WD Element & CR-V
ac compressor clutch coil failed again
Old May 30, 2013 | 01:09 PM
boffin1946's Avatar
Default ac compressor clutch coil failed again
The ac was not working and found that the clutch coil was bad. Replaced it and it worked fine for a day, about 3 hours of driving. what could cause the coil to fail? I didn't check pressures after the coil was replaced. I am thinking of replacing it again but would like some hope that I can figure out what is causing the coil to fail. What should I check after I replace it?
The only idea I have is that I hit a dog about a month ago and the condenser was slightly bent and this is restricting flow or reducing cooling causing the compressor to run longer and overheating the coil
Old May 31, 2013 | 04:12 AM
dogbiscuit's Avatar
Default Re: ac compressor clutch coil failed again
If your system is low on freon the compressor will not kick on
Old Jul 1, 2013 | 11:31 AM
boffin1946's Avatar
I solved my problem. I feel so stupid. When I put the coil in, I did not fully set the split ring that holds it in place. It slipped out and rubbed against the clutch and cut into it. I even had problems getting the second coil to lock in place. I would try to gently pry the coil up and the split ring would not hold. I finally had to tap the split ring down into the slot with a punch and hammer.
The first time i did it on the car. The second time I had the compressor on the bench.
Carey Lynch
Aug 9, 2018 11:15 AM
tashascivic
Honda Civic (2006 - 2015)
Jul 11, 2013 09:52 PM
Civic05'
Honda Civic (2001 - 2005)
25
Jun 17, 2013 10:19 PM
Andrei71
Sep 3, 2010 01:21 PM
