AC Replacement - NEED HELP!!
Old May 30, 2013 | 06:03 AM
mrbarwrobert's Avatar
Default AC Replacement - NEED HELP!!
So I have a problem where when I turn on the A/C my car loses most of its power. I turned the clutch by hand and found that it hangs up every time you make a full 360 degree rotation. I am assuming that this is bogging down the system which is causing the power failure...just wanted to get someones opinion on this.
Also, the system had r12, so from what I have read I need to replace a few things...
Compressor w/clutch
Drier
Expansion Valve
o-rings
Does this sound right?
Any guidance would be highly appreciated!!
Thanks!!
Old May 30, 2013 | 12:25 PM
Jonathan_ED3's Avatar
Default Re: AC Replacement - NEED HELP!!
That's a start yes.
Are you staying R12 or converting to 134?
I would recommend staying R12 if you can find it
Old May 30, 2013 | 12:28 PM
Jonathan, if I stay R12 could I not just replace the compressor and clutch then?
AZCR-V
Honda CR-V & Element
Apr 23, 2018 07:58 AM
JNX
Honda Civic (2006 - 2015)
Jul 29, 2013 02:10 AM
dstatechamps
Jul 26, 2011 04:21 AM
jabroni95gsr
Dec 18, 2002 07:00 AM
