Need bolt in muffler replacement
Old May 29, 2013 | 07:36 PM
VtecAddict96's Avatar
Default Need bolt in muffler replacement
Hi,
I have a 1996 Civic ex coupe 5spd.
I've used a greddy sp2 exhaust for the last 6-7 years. However, now the baffling in my muffler has essentially fallen into my muffler and is rolling around making a ton of metal rolling/clanging sounds. The rest of my exhaust looks like it's still in pretty good condition.
I need a direct bolt-on muffler replacement for this. I'm not interested in power or sound(quiet as possible please) because this is now my beater vehicle. Does anyone have recommendations on a direct bolt in replacement that I could order and bolt in? Do you foresee there being any issues because I have the sp2 piping and not the OEM piping?
Greddy discontinued the sp2 and it doesn't look like I can order just a muffler from them anyways. I really don't want to pay a muffler shop $300 to do this when I know if I could buy a bolt-on for $100 I could do it myself.
Thanks!
Old May 30, 2013 | 12:07 AM
B_Swapped93's Avatar
Default Re: Need bolt in muffler replacement
by "bolt in" you mean cut off old muffler then weld in new one as buying a new axel back would be pretty stupid. the vibrant stealth is pretty quiet in terms of things looks like a normal muffler also no 4'' tip of the flare style the greddy or ws2 have. 300$ lol muffler 100+10$ weld if you take the axelback off and bring it to any shop around here sure i'd be the same for you.
Old May 30, 2013 | 02:16 AM
Mr. Bojangles's Avatar
I'm in the same boat right now since my WS2 was stolen the other night, I have an OEM spec muffler I bought from Pepboys on there temporarily and it doesn't quite fit correctly with the rest of the cat back system, the piping diameter is too small, creating a leak where it bolts up by the axle, but I needed something to tone it down. Ordering a Vibrant tomorrow for like $100.
Old May 30, 2013 | 03:02 AM
street93eg's Avatar
Get a borla or manga flow oval muffler. They sound really good and weld up under the car nicely.
I did a high temp black paint on mine so as not to draw attention to the muffler and it blends well with the back of the car
Old May 31, 2013 | 09:39 AM
Initially I was thinking axle-back but now it seems that would be a little more expensive and the piping still looks like it's holding up.
I don't know what borla or magnaflow muffler would actually line up correctly with the 60mm piping I have and fit underneath the car ok and one that would be quiet, I can only guess by pictures. I have no way of seeing any of these mufflers in person.
I was quoted $75 to weld in a new muffler but I still don't know what muffler I should order. Anyone have any similar experiences and can recommend one?
Thanks
This seems to be the best bet I've found so far, but it's only 2" piping so I just wonder if that's too small:
http://www.carid.com/1992-honda-civi...Fc9FMgodLV0AVA
Or this 2.5":
http://www.jcwhitney.com/flowmaster-...c10832d894u0j1
Old May 31, 2013 | 01:20 PM
75$ for a weld lol don't get ripped of that badly I pay 0-20$ max around here at any garage. 60mm=2.36'' which is 2.5'' OD that 2'' will be to small the 2.5 is what you want there are no exhausts that I know of that are actually 2.5'' my Buddy club spec2 is 2.45 ID but that's the closest I've seen
Old Jun 1, 2013 | 03:46 AM
street93eg's Avatar
Wow, 75 dollars... those guys must be smoking something really good! I wouldn't charge half that much and I would get crazy and TIG weld it just for giggles. If you lived nearby I would just show up and weld it for you for free but currently its a hell of a drive from japan.
You can get the manga flow in a 2.5 and they do have it with different tip locations to fit your needs.
joytjuhhhh
Jan 27, 2015 04:42 PM
Spazbaboon
Dec 28, 2006 01:11 PM
megaman096
14
Nov 29, 2004 06:21 PM
LBC vee
Aug 4, 2002 11:34 AM
Zymotix2
Feb 14, 2002 10:42 AM
