Exhaust questions.
Old May 29, 2013 | 12:50 PM
Wdpfreak145's Avatar
Default Exhaust questions.
Alright guys. I have a few other loose ends to tie up before I can get my project started and running. I am currently running a multi-piece catback exhuast and test pipe. This is all ebay stuff. But it is intended to be interchangeable with stock exhaust components, so the piping should still be the same.
I need to know where I can order two and three bolt exhaust flange gaskets of a certain diameter.
I also need to know what the dimensions are on the spring bolt that connect the header/exhaust manifold to the cat/test pipe. I did not run any the first time and the fitment was poor and I wound up bending my test pipe flange. Someone mentioned being able to find them at a parts store like autozone or advance, so I just need to know what kind to get.
And does anyone have a felpro part number fort the gasket that goes between the exhaust manifold and the cat? Most people refer to it as a donut gasket.
Old May 29, 2013 | 09:25 PM
Default Re: Exhaust questions.
Over a hundred views and no answers or advice? Bump.
Old May 30, 2013 | 12:01 AM
B_Swapped93's Avatar
So you didn't use springs bolt the first time. go to the hard ware store grab 2 springs and bolts that fit threw the holes of the exhaust manifold and test pipe. as for length 7-10 inches area there's usually plenty of room down there anyways.
Old May 30, 2013 | 06:11 PM
cidgrad130's Avatar
Summit Racing is a good source for 2 and 3 bold flanges and gaskets.
For the "donut gasket" why not just order the OEM piece fom Majestic?
Old May 30, 2013 | 08:54 PM
I am trusting FelPro for all the gasket needs I can on this build. They have not failed me yet (rear main, exhaust manifold gaskets, throttle body, intake manifold, valve cover set) so I want to maintain that consistency across the build.
I will start checking summit with the flange types and pipe diameters. Thanks for the advice. Still looking to see if anyone knows about the spring bolts with some specific information.
Another_Si_Guy
11
Dec 7, 2015 08:44 AM
20mph
Aug 5, 2015 05:32 PM
Si-Samuri
13
Oct 16, 2009 02:02 PM
CivicSi95
Feb 24, 2009 11:31 AM
Hill4589
Aug 27, 2008 02:44 AM
