distributor inner seal question
Old May 29, 2013 | 01:52 AM
jwarren1904's Avatar
Icon2 distributor inner seal question
Im replacing the inner seal on my distributor and was wondering which way does the seal go in? do I place it in with the "nok" brand face up or down. also in this video I watched the dude had a garter ring along with the seal, I don't, is it important?
Old May 30, 2013 | 02:59 AM
holmesnmanny's Avatar
Default Re: distributor inner seal question
there's a spring that goes around the inside of the seal which puts pressure on the lip of the seal to prevent leakage...the spring side will be away inside the housing
Old May 30, 2013 | 03:22 AM
I don't have that spring, will I leak?
Old May 30, 2013 | 03:26 AM
TBH, it probably will. It should have came with it. Did you fiddle with the seal or something ? It is possible for it to come out with only a little pressure. You should try looking around on the ground and find it. Also, that seal will not work with most aftermarket distributors nor will a spring from one work on yours because they usually vary in size and size of the housing.
Cody Pereira
13
May 13, 2019 09:02 AM
Juans_MX3
10
Apr 21, 2011 05:17 PM
Si-Samuri
Oct 27, 2008 07:45 AM
solfly
Aug 25, 2005 06:16 PM
